Форум РадиоКот • Просмотр темы - Проблема с приемом через DMA на STM32F103
Текущее время: Сб дек 27, 2025 23:49:11
 Заголовок сообщения: Проблема с приемом через DMA на STM32F103
СообщениеДобавлено: Пт май 20, 2022 14:11:56
Карма: -12
Рейтинг сообщений: -24
Настраиваю I2C так:
// setup DMA receiver
static void i2c_DMAr_setup(){
    /* Enable the peripheral clock DMA1 */
    RCC->AHBENR |= RCC_AHBENR_DMA1EN;
    DMA1_Channel7->CPAR = (uint32_t)&(I2C1->DR);
    DMA1_Channel7->CCR |= DMA_CCR_MINC | DMA_CCR_TCIE;
    NVIC_SetPriority(DMA1_Channel7_IRQn, 0);
    NVIC_EnableIRQ(DMA1_Channel7_IRQn);
    I2C1->CR2 |= I2C_CR2_DMAEN;
    i2cDMAr = I2C_DMA_RELAX;
 * PB10/PB6 - I2C_SCL, PB11/PB7 - I2C_SDA or remap @ PB8 & PB9
 * @param withDMA == 1 to setup DMA receiver too
void i2c_setup(uint8_t withDMA){
    RCC->APB2ENR |= RCC_APB2ENR_IOPBEN;
    GPIOB->CRL = (GPIOB->CRL & ~(GPIO_CRL_CNF6 | GPIO_CRL_CNF7)) |
            CRL(6, CNF_AFOD | MODE_NORMAL) | CRL(7, CNF_AFOD | MODE_NORMAL);
    RCC->APB1ENR |= RCC_APB1ENR_I2C1EN;
    I2C1->CR1 = 0; // clear all previous settings
    I2C1->SR1 = 0;
    RCC->APB1RSTR |=  RCC_APB1RSTR_I2C1RST; // reset peripherial
    RCC->APB1RSTR &= ~RCC_APB1RSTR_I2C1RST;
    I2C1->CR2 = 8; // FREQR=8MHz, T=125ns
    //I2C1->CR2 = 10; // FREQR=10MHz, T=100ns
    I2C1->TRISE = 9; // (9-1)*125 = 1us
    //I2C1->TRISE = 4; // (4-1)*100 = 300ns
    I2C1->CCR = 40; // normal mode, 8MHz/2/40 = 100kHz
    //I2C1->CCR = I2C_CCR_FS | 10; // fast mode, 10MHz/2/10 = 500kHz
    if(withDMA) i2c_DMAr_setup();
    I2C1->CR1 |= I2C_CR1_PE; // enable periph
Вот так запускаю прием
 * @brief i2c_7bit_receive_DMA - receive data using DMA
 * @param data    - pointer to external array
 * @param nbytes  - data len
 * @return I2C_OK when receiving started; poll end of receiving by flag i2cDMAr;
i2c_status i2c_7bit_receive_DMA(uint8_t *data, uint16_t nbytes){
    if(i2cDMAr == I2C_DMA_BUSY) return I2C_LINEBUSY; // previous receiving still works
    if(i2cDMAr == I2C_DMA_NOTINIT) i2c_DMAr_setup();
    i2c_status ret = I2C_LINEBUSY;
    DBG("Conf DMA");
    DMA1_Channel7->CCR &= ~DMA_CCR_EN;
    DMA1_Channel7->CMAR = (uint32_t)data;
    DMA1_Channel7->CNDTR = nbytes;
    // now send address and start I2C receiving
    I2C1->SR1 = 0;
    I2C1->CR1 |= I2C_CR1_START | I2C_CR1_ACK;
    DBG("wait sb");
    I2C_WAIT(I2C1->SR1 & I2C_SR1_SB);
    (void) I2C1->SR1;
    I2C1->DR = addr7r;
    DBG("wait addr");
    I2C_WAIT(I2C1->SR1 & I2C_SR1_ADDR);
    if(I2C1->SR1 & I2C_SR1_AF) return I2C_NACK;
    (void) I2C1->SR2;
    DBG("start");
    DMA1_Channel7->CCR |= DMA_CCR_EN;
    i2cDMAr = I2C_DMA_BUSY;
    ret = I2C_OK;
eotr:
    return ret;
Обработчик прерывания DMA:
void dma1_channel7_isr(){
    I2C1->CR1 |= I2C_CR1_STOP; // send STOP
    DMA1->IFCR = DMA_IFCR_CTCIF7;
    i2cDMAr = I2C_DMA_READY;
Размер приемного буфера - 832 слова uint16_t.
Проблема: если я принимаю небольшое количество символов (скажем, 100 или 200), то проблем нет и все работает. Но как только запускаю прием всего буфера в 832 слова, SDA оказывается подтянутой к нулю и линия "встает"! Повторная инициализация I2C (которая начинается со сброса) не помогает. Спасает лишь перезапуск сидящего на шине устройства (по питанию).
Если то же количество данных я принимаю по-тупому "в лоб" (т.е. отправил регистр, получил значение, удлиняя время получения данных больше, чем в два раза), то никаких проблем не происходит.
Что винить: мои кривые руки (но вроде обработчик прерывания по окончанию приема DMA по мануалу делал: там написано лишь выставить в I2C флаг STOP) или же устройство, охреневающее, что из него так много данных за раз считывают?
Запитано устройство через p-канальный мосфет, от 3.3В. По умолчанию затвор подтянут килоомным резистором к питанию, а для включения МК подтягивает затвор к земле. Питание у устройства отдельное, т.к. на используемой "blue pill" дурной SDO: выдает 3В всего, а если питать от ноги МК, то проседает до 2.8В в режиме сна и 2.6В в режиме работы. С отдельным же питанием на осциллографе по питанию все ровно: и во время сна, и во время работы.
Добавлено after 13 minutes 44 seconds:
Методом тыка заметил странную вещь: если разорвать SDA к устройству, попытаться что-то отправить в I2C, затем обратно соединить - работа I2C восстанавливается!
Пойду читать методы восстановления I2C без передергивания питания устройства. Если не поможет, придется считывать буфер в два захода - по половинке.
Добавлено after 8 minutes 12 seconds:
Дальнейшим методом тыка выяснил, что устройству почему-то не нравится, когда я посредством DMA читаю из последних 128 байт памяти (начиная с любого адреса в этой зоне).
Причем, данные-то отдает правильные, но потом завешивает I2C! В даташите на устройство (MLX90640) ничего особенного про I2C не написано: стандартный протокол... Правда, там написано, что скорость от 400кГц до 1МГц, но т.к. у меня все на столе с проводочками, я на 100кГц работаю. Вместо 1кОм поставил подтяжку в 2кОм - наверное, поэтому фронты чуть завалены, но осциллограмма вменяемая.
Я на гитхабе, в ЖЖ
